autocorrelation of light scattering data - a problem
In my work I will be acquiring light scattering data, so I will be measuring the intensity of the light as a function of time (my time intervals will generally be 5ms).  One of the things I then want to do with my data is to run an intensity autocorrelation function on it; we want to be able to access the initial slope of the autocorrelation function.
So I found that there was an autocorrelation vi in labview.  I put together my vi and ran it and worked out how to add my time intervals (ie after running the autocorrelation function).  It was then that I realized that something seemed to be wrong.  What I realized was that the number of data points I was getting back from the autocorrelation function was nearly double the number of data points of my data; for example my data is 100,000 points, I was getting back something like 199999 points.  Given that I need to be able to equate my delay times with the corresponding autocorrelation data this left me with a problem.  So I went back and read the help files with regards to this vi and realized why I was getting so many data points, the output sequence is 2N-1 and thus t=0 is the Nth element of the output sequence.
So given that I want to have access to the initial slope of the autocorrelation function (ie on the right hand of the x-axis relative to where t=0 would be), and I would prefer not to have to actually write out my own autocorrelation vi (that I have found is not as easy as it looks), I have been trying to work out how to extract the data from the Nth element onwards.  So far I have been unsuccessful in doing this.
Note that from what I have gathered when an autocorrelation is done on dynamic light scattering data you essentially get an exponential curve and when I do eventually get some proper data to play with I would expect something similar (the data I have attached is some random noise I have generated so that I can work with my vi’s at the moment).
So any help in working out how to extract the relevant data would be appreciated.  I have attached my original autocorrelation vi and the one I have modified.  This was the final modification and it wasn’t able to extract the data I am after.  I have also included one of the ‘data’ files I have been working with (ie the noise data).
I am using LV 8.6 and thanks for any help that can be provided, or suggestions as to alternative approaches as well.
(3,784 Views)
Hey, not a huge fan of bumping threads (although I am doing that now), cos I think my original post got lost in the posts at the end of last week.
(3,752 Views)
Accepted by topic author scottum
Hi scottum,
Are you asking how to extract an array subset of data points? I would use the Array Subset with the starting position being N (from the array size before) and the length being the remaining length of the output (again, using Array Size).
Please correct me if I'm not understanding your question.
Jeff | LabVIEW Software Engineer
(3,724 Views)
Thanks Jeff, that looks like it works the way I wanted it to work.  Thanks for the help.
I think I had tried to use the subset array, but not with the connections you suggested and also not making use of the array size vi as well.
(3,700 Views)
