automate ni cRIO 9075 labview
Bonjour, je voudrais savoir comment peut on configurer l'adresse de l'automate NI cRIO 9075 avec labview, car je débute sur labview et je n'y comprend rien.
Cordialement Merci
(2,894 Views)
Are you asking how to configure the IP address of the cRIO? You can do this using Measurement and Automation Explorer (MAX). You will need to have the cRIO plugged into the same local network as your computer. When you expand the Remote Systems item in MAX, it should search and find the cRIO, and then you can set the address.
(2,866 Views)
Hi Laurent,
for each of our product you have a getting started pdf document available on the related web page.
It explains everything you need:
9075
Best regards
Romain DUVAL || RF & Semiconductor Staff System Engineer || CLA || CTA
National Instruments France
(2,840 Views)
