automatic array creation
I am trying to build an array automatically by use of boolean array. I use for loop in the VI but when the boolean array false it assigned "0" into the array. I do not want to assign "0", instead of, I want to pass this step and assign when the boolean array element true. How could I do it?
Egemen
Message 1 of 10
(4,028 Views)
When the boolean is true, assign your next value to the array and put that next value into a shift register.
When the boolean is false, put the previous value from the shift register into the array, and pass the value in the shift register through to put it back into the shift register.
Message 2 of 10
(4,019 Views)
Actually, I could not understand how could I do? I tried but...
Egemen
Message 3 of 10
(4,012 Views)
Autoindex the two input arrays.  Then you don't have to index them out yourself.
You need to store the output array in a shift register.  Initialize it to empty.  Now when the boolean is TRUE, you use the Build Array to add the numeric to the array.  When the boolean is FALSE, you just pass the array straight through.
Message 4 of 10
(4,002 Views)
I thought I do not understand what you said. I could not wire an array to a shift register. I tried to do sth but it does not work 😞
Egemen
Message 5 of 10
(3,997 Views)
I explain it again via printscreen.
Egemen
Message 6 of 10
(3,986 Views)
Accepted by topic author newbieeng
Use the Build Array in the TRUE case!
Also, create an array constant and wire that into the shift register in order to initialize it.
If you are this lost, you really should go through the LabVIEW 101 tutorials.
Message 7 of 10
(3,979 Views)
of course you COULD use the Conditional tunnel from the array functions in the Open G toolkit
Message 8 of 10
(3,976 Views)
Or upgrade to 2012 which has the conditional autoindexing tunnels.
Message 9 of 10
(3,972 Views)
Thank you very much. I was trying to constitute it without build array function that's why I stuck in that.
Egemen
Message 10 of 10
(3,965 Views)
