automatic close window media player
hi,
In my application i am opening window media player after occuring 1 condition.It plays clip of 19 sec.
i want that player should  get closed automatically,after playing clip.how is it possible? I have used property node and invoke node properties to open window media player.
Thank you
gak
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
(3,146 Views)
Hi Gak,
Just wondering, are you opening and running Media Player in a different window to LabVIEW or is Media Player embedded in a second front panel? I would expect that there would be some form of property or method node that could be used to close it. Perhaps if you could attach a copy of your VI I could look into the issue further. Look forward to hearing back from you,
Best Regards
Jeremy T
Technical Marketing
NI
(3,122 Views)
(3,112 Views)
hi,
Thank you.this is what i wanted.
again Thanks
gak
Gaurav k
CLD Certified !!!!!
(3,095 Views)
