05-13-2009 09:54 AM - edited 05-13-2009 09:57 AM
Dear All
I am trying to create a program where based on text input, an XY stage will move to draw out the trajectory. For example I input the letter "A" and the stage moves to draw out the same. I want it to move as if the letter was made up of 'dots' placed at a specific interval.
Currently I do this manually. For example I write a program which moves the stage a specific distance and direction using loops (for each letter I have to write a separate program). I want this to be automated wherein LabVIEW would detect the letters, converting each to be made with a succession of dots and then move the stage accordingly.
I don’t know whether this is possible using LabVIEW or if there is an easier way to do it. ( For ex. drawing the shapes using dots within LabVIEW itself). I would appreciate your thoughts and help on this.
05-14-2009
05:52 PM
- last edited on
11-10-2024
04:54 PM
by
Content Cleaner
Hi rutgers,
As far as reading letters, you could look into the Optical Character Recognition functionality.
As far as the letters as dots, I'm not sure what data type you're using. You say you draw the letters manually and then translate this motion motion. How so? Seems like a neat application.
I hope this helps!
Kristen H.
05-15-2009 12:45 AM
I think you need to write a "letter driver" i.e. you need to define a starting point for your letter and then define the XY points, in some array, where you need to go ('ve been using this for XYZ motors, but I needed only vectors...)
regards
05-15-2009 12:55 AM
A suggestion...
If your string length is fixed then you can create a control similar to seven segment LED display-> generate the binary pattern for each letter->illuminate the LED's corrosponding to each segment![]()
post back for queries.
05-15-2009 06:18 AM
05-15-2009 08:01 AM - edited 05-15-2009 08:10 AM
Hi rutgers
Find the attached vis that seams like solutions of your problem.
Click on "kudos" and see the MaGiC.....!!!!![]()
05-15-2009 12:52 PM - edited 05-15-2009 12:53 PM
Hi everyone
Thanks for the ideas everyone has come up with. One thing I would like to point out is that I am not interested in just letters but any patterns that are input by the use. I was using letters as a starting point.
@ kristen Thanks for the tip regarding OCR, will look into it
@ nitad54448 Can you elaborate little bit more, also what do you mean by needing only vectors.
@JK1 the seven segment setup is interesting but I would restrict the characters/patterns I could form, and yes, string length would be fixed.
@Mike I looked into dot matrix and seems like a long process (time to implement is limited)
@ Malhar Can you please convert the vi into Labview 8 as that is the version that I have.
Once again thank you everyone for their inputs and kudos!
Regards
Abhishek
05-15-2009 02:04 PM - edited 05-15-2009 02:06 PM
I've used this for vectors myself (on a XYZ stage) but I think you can do this by "letter drivers", as it was the case for the dot-matrix printers twenty years ago.. Suppose you want to write the letter A (or any other pattern for that matter) , and say you want to "write" it with 12*12 resolution. In a table (which you must create first, this is the "driver") you look for the position of "dots" on X and Y, let's say 1,1; 1,3, and so on for all the dots you want to "write". One problem with this method is that you need to create tables for all characters you want to "write"; another one is in the efficiency.. in order to limit the movements you need to look at graph-theory, that is way over my head...
regards
EDIT : did't see it before, Malhar's solution seems fine...
05-15-2009 11:58 PM
Hi abhishek,
Find the vis attached herewith, its for labview 8.0. you can print almost all the cherector contains in standard keyboard into xy graph.
