automatic gain controller
Hello there
I want to cretae an automatic gain controller with LabView. I was therefore looking up examples to understand how it works. I did find an example for the same, but it utilizes the NI LabView DSP Module and its various sub VIs. I tried installing the evaluation version of the Advanced Signal Processing toolkit (since the DSP module is not available now). The VI still shows errors and is unable to find some of the sub VIs being used in the main VI.
Is there any way I can access the example VI to look into the code. I don't want it to work necessarily. Kindly help me out with this.
In case, there is no way I can access the code from the example VI on AGC, can some one help me understand the concept better so that I can create a VI for myself.
Thanks in advance.
P.S: I have attached the example VI that I found on the NI website for the automatic gain controller (AGC)
Message 1 of 1
(3,857 Views)
