automatic launch impossible to disable
I'm a user of Labview since many years. Actually i'm using a 8.2 pro version to develop and build my executables. Since a few weeks, when I build my exe, they are always starting automatically, even if I disable the 'auto launch at starting' option in the exe builder. Is there any way to fix this??
Thanks in advance for help,
Chris
(4,213 Views)
Hi.
Could you make an example and send it on the forum, because it's really strange that disabling the option doesn't work?
Thank you
Best regards
(4,174 Views)
Here you have the .vi, the .lvproj, plus the .exe I made.
Bye,
(4,167 Views)
Hello.
I built the exe again and the exe didn't start at launch. I suggest you to build it again.
Best regards
(4,130 Views)
Did you perhaps install a different LabVIEW verion a few weeks ago?  It might be a little bug with the app builder (LabVIEW uses the latest installed app builder)
(4,122 Views)
Hello.
Which version of LV do you use?If you have a professionsal edtion, LV uses the application builder related to the version of LV version you are using.
Best regards
(4,117 Views)
As I said, I'm using a 8.2 pro version. I also just realized that i've 3 different versions of the run-time on my computer (7.1, 8.0 & 8.2). Could it interfer with something??
Concerning my versions of LV, we bought a version 7 and finally we had free upgrades until the 8.2 version. I just changed my computer for a new one (winXP), so I directly intalled the 8.2 version.
I also rebuilt the exe with the lvproj mentionned above, but the result is the same, the exe starts alone....??
Thanks for your help,
Chris
(4,086 Views)
