automatic string formatting algorithm
What is LabVIEW’s algorithm for automatically formatting numbers?
I’m porting some LabVIEW code to C#, and I want to exactly duplicate the functionality of LabVIEW’s “Format Into String” function with “%#_6g” for its “format string” input.
(4,118 Views)
I don't understand your question. What do you mean by the algorithm for automatically formatting numbers? The Format Into String function outputs a string based on the format that you specify, so there's nothing "automatic" about it. It's no different than String.Format().
(4,106 Views)
That letter "g" in the string "%#_6g" means LabVIEW is automatically formatting the number between floating point and scientific notation.
To see this, drop a numeric control on the front panel, pop up on it to select its "Format & Precision..." menu item, then switch between "Automatic formatting" and any other format in that list, like "Scientific". When you switch to a new item in that list, switch to "Advanced Editing Mode" to see that the Format string has a "g" in it when it's on "Automatic formatting".
(4,089 Views)
The %g format system works like this:
If the exponent of the number is between E+5 and E-4 (inclusive), it will format it as a normal floating point (%f) but if the number is outside this range it will have scientific notation format (%e).
Message Edited by Karissa on 08-14-2008 10:29 PM
_______________________________________
Systems Test Engineer
Certified LabVIEW Architect (CLA)
(4,077 Views)
That seems simple, thanks.
(4,061 Views)
