automatic switch
does anybody have a idea how to create an automatic booleon switch? I want it to switch on and off every 20 seconds
Message 1 of 9
(5,612 Views)
Hi Jack,
-create a while loop with a shift register
- init the shift register with a FALSE constant
- wire from left SR to right SR, insert a NOT function in the wire
- create an indicator for the wire
- place a delay function in the loop, wire 20000 to it
Ready...
Message 2 of 9
(5,610 Views)
it worked.....thank you so much!
Message 3 of 9
(5,607 Views)
Jack,
Are you trying to actually move a switch control, or are are just needing a 50% duty .05Hz signal?
Do you need it to run inside another process and not hog all the vi's resources?
Red
Certified LabVIEW Associate Developer
VI Technology
Message 4 of 9
(5,577 Views)
Here is an example using a statemachine.
Red
VI Technology
Message 5 of 9
(5,574 Views)
I have another question. I have 2 loops in my program and I want 1 loop to have a time delay. What i mean is 1 loops is executed and the other is executed after a specific time. I tried the time delay vi and its not working. any ideas? I really need this program running by friday so that i can conduct the test on the weekend and this problem is my only obstacle. Hope to get a reply as soon as possible
Message 6 of 9
(5,557 Views)
How is your program not working?
Post your VI so we can see what you are trying to do.Smiley Wink
Message 7 of 9
(5,548 Views)
I have attached the program. The bottom loop should be executed after the 1st loop
Message 8 of 9
(5,537 Views)
Hi jackofall...,
therefore connect the second loop with a wire from the first loop.
Mike
Message 9 of 9
(5,520 Views)
