automatically adjusting range on indicator
Hi!
So, I think I might be having a brain fart because there should be a simple solution to this, but I can't figure it out right now. All I'm trying to do is for the scale on the indicator to automatically adjust itself when it becomes larger than a certain value.
If the value is between 1-10, the scale goes up to 10
If the value is between 11-100, the scale goes up to 100
If the value is between 101-1000, the scale goes up to 1000
and so on.
Help please! I've attached below what I've done so far. But yeah, *block*.
Thanks!
~Nadia
(3,260 Views)
Here's a quick draft that works for all cases. (try e.g. 0.004, 34, 100003, etc.)
Message Edited by altenbach on 04-15-2008 03:06 PM
(3,259 Views)
Yes! Thank you!
Hah, log scale... that's what I was needing. 🙂
(3,251 Views)
Log scale mapping for scales is something else.
My example uses linear scales.
(right-click on the axis...mapping... to see the difference)
(3,248 Views)
