automatically launch executable after the installation of this executable
is there a way to automatically launch the EXE of a NI customized installer immediately after the end of the installation, as we can see in lots of common software installers?
I've test "installer properties->Advanced -> Run executable at the end of installation" but I realized it's a wrong way to do that.
thanks for your help
Pierre FCentum TNS, Grenoble
Certified LabVIEW Associated Developer
(997 Views)
You can enter your just installed exe into that field, but then it will run with elevated privileges.
To avoid that, you can create a bat file that is called after the installer runs. Give it "[INSTALLDIR]" (including quotation marks) as argument and then in the file something like this:
cd %1
runas /trustlevel:0x20000 "myapp.exe"
I have no prior experience with this, but maybe it helps 😄
(944 Views)
With the solution above, if the installer was run as a different user (i.e. one with admin privileges) then the application will be executed under that user's account.
Out of curiosity, I looked up how Notepad++ does it and their solution is basically:
"%windir%\explorer.exe" "myapp.exe"
Which apparently launches myapp.exe with the same privileges and as the same user as the explorer process. Drawback is that passing command line arguments does not work.
(921 Views)
