automating absolute or relative mode on graphs
I want to make a control trigger an event on my vi front panel, which will toggle the time x graph mode from absolute to relative mode.  I can't seem to find the property or method where I can access this mode.  When right-clicking the graph control it is under properties/display format/type.  Anyone know where I can dynamically change this during runtime?  I'm looking under the properties/methods of the graph control reference, can't seem to find it.
Thanks for any help
David J.
(2,844 Views)
Accepted by topic author david_jenkinson
Hi David,
Right-click the graph terminal and select: Create> Property Node> XScale > Display Format > Format
steve
Founding (and only) member of AUITA - the Anti UI Thread Association.
(2,815 Views)
