automating usb-6501 to generate(DO) at its respective port , if given command (boolean command) is given
the following "attached png " is for selecting one channel at a time and taking a digital output from the respective port.Now instead of doing it manually for the individual port i want to automate it as in the pic, describing as:
1. say, i have  4 DO of usb -6501, by switching the boolean(ON) i want the  ports 1,4 (3,2 to be OFF)to display the output,one after the other
2.i want to simultaneously take the output of any of these points(1,4)ON, together(like LEDs are lightening together).
(2,078 Views)
write to DAQ all lines in array
Of course you need configure DAQ for all lines, not one
(2,065 Views)
