average of consecutive elements of array
HI, i want to find the number of consecutive elements in array, calculate the average of each consecutive chunk,  Output should be tow arrays as shown in attatched image.
array2 shows the number of consecutive elements in each chunk.
array3 shows the average of consecutive elements in each chunk.
(3,533 Views)
Accepted by topic author zeeshanhameed
Your average of 11,12,13 and 21,22  are incorrect.....
Use a For loop to iterate through the first array and use shift registers to keep an array of previous values in memory. Use this array of previous values to compare the current value with the previous. If there is a gap of greater than 1, output the average of the array and clear it. Write the newest value tot he shift register.
Here's what I mean: (It can be cleaned up a bit, but it works)
Cheers
(3,529 Views)
Thank you sir
(3,483 Views)
