averaging a VEEEEERY BIG (10 MB) arrays` elements
altenbach (the old but good man)
10 because 9 + 1 for the carriage return ?
For headers: I have no idea how many lines will be exist in header so I can`t set headers staticly... to show them in a string as your first solution would be perfect.
as last I need to search this certain field "Range" from the string and read it out to use it for next steps...
pls , I have no more question after this ! ( i promise )   :))))))))))
thnxxxxxxxxxxxxxxxx
Message 31 of 34
(819 Views)
I have managed ! thnx alot for you helps... really deeply 😉
to change to I16 ? I am searching
Message 32 of 34
(817 Views)
I managed all ! thnx again
Message 33 of 34
(812 Views)
I've been following this thread to see how you've fared. Based on your posts and questions it seems obvious that you really need to spend some time with the LabVIEW tutorials and courses. I would suggest starting here.
Message 34 of 34
(791 Views)
