averaging of 1D Array
I have a 1D array of 2000 elements. Now I want to get another array of 2000 elements in which each element will be the 200 points average of previous array.
means, X[100]= Sum (X[1]: X[200])/200   somthing like that.
how to do it?
(3,238 Views)
Could you please post what you have tried so far? Based on that we will suggest you how to proceed.
Mathan
(3,219 Views)
I'd split the array up into 10 parts then use Mean.vi to find the average of each part (Mathematics>Probabiltity and Statistics), then put the ten values you get back into an array using 'Build Array'
Hope this helps 🙂
Jack
(3,216 Views)
Hi sukhiray,
see this link
http://forums.ni.com/ni/board/message?board.id=170&view=by_date_ascending&message.id=328437#M328437
The lower part should work for you.
Mike
(3,215 Views)
Do you mean a moving average or something else ?
(3,212 Views)
