avi and wave format
hello,
i have a little problem with labview. i record audio and video separat. now i wanna play the files in windows mediaplayer together. how does it work. i hoppe someone can help me...
bye chris
(3,011 Views)
you could use a separate program to multiplex the audio and video to one file. One of such program is called VirtualDub and can be obtained from here.
Another way is to use two media player activeX instance in your vi, one play the video (visible) and the other play the audio (can be hidden). You control both instance in the same loop.
-Joe
(3,000 Views)
thank a lot for your quick answer...
(2,994 Views)
