avoid indexing inside the loop
hi ..
Can i improve the code in attached vi? can i reduce the indexing inside the loop?
thank you,
Ranjit
(3,093 Views)
You can initialize the array before the for loop and inside use the replace element function.
At the end you can resize your array to the final number of elements.
How big is your input array?
If it is small, you should not have any problems,
(3,087 Views)
If it is small, you should not have any problems, as it is
Message Edited by Pnt on 07-18-2008 08:25 AM
(3,087 Views)
Unfortunately I do not have LV installed on this PC therefore I could not look at your code.
However, if you are using a loop only to deal with an array, please note that many functions (VI) are polymorphic and will deal with arrays without the use of a loop.
R
(3,056 Views)
What are you trying to do?
(3,036 Views)
