avoid the search message in build application
When we build an application LabVIEW. At runtime, LabVIEW pop a dialog that displays searched VI. How come this appear if I already added the supported VI at Build time. And how can I avoid theses search...
(2,603 Views)
I haven't seen this happen with the application builder, but in the LabView environment that's often due to a sub-VI that was moved. A LabView VI remembers the path to each sub-VI it calls. If the sub-VI was moved without re-saving the calling VI, the next time you load the calling VI, it will search for the sub-VI. To correct the problem (and stop the search), re-save the calling VI.
(2,603 Views)
