avt guppy pro Setting
Hi Guys
I am trying to set the AVT Guppy pro camera setting with LabView but it does not have effect on image camera captured. The Register value has changed by reading the the register in the camera. After taking a picture, the register value changed by to the old value. Do you have any idea?  The picture below is how i change camera setting
Best Regards
Wenjie Wang
(3,800 Views)
Hi Wenjie1 Wang,
Could you please clarify your question a bit? What is the register you mentioned in your post?
I look forward to your reply.
Thank you.
Lanxi
(3,753 Views)
F1000208  Time Base
F100020C Extended Shutter
F0F0081C Shutter
F0F00820 Gain
F0F00804 auto exposure
F0F00800 brightness
I was trying to set these values
(3,744 Views)
Hi Wenjie1 Wang,
Thank you for your prompt reply.
The permanent attribute changes need to be done via MAX or the camera files.
Any problem please let me know.
Lanxi
(3,731 Views)
Hi, i did not use attribute, and i just write to register value directly using IMAQdx write register and write register directly to the camera
(3,720 Views)
Hi Wenjie1 wang,
I don't know if you have looked at this forum post before, there are several points mentioned in it is worth checking:
"Reading and Writing to Camera Registers with IMAQdx":
https://forums.ni.com/t5/Machine-Vision/Reading-and-Writing-to-Camera-Registers-with-IMAQdx/td-p/119...
Thank you.
Lanxi
(3,714 Views)
