background color of a chart or graph
Hi everybody,
I am plotting an X-Y Chart, I want to have a total white background and the sketching xy value in black. I dont want gitters or sth else. Just black white graph.
How is this possible to do? I found the back ground color can be changed through the property node, but the others I can`t find.
any answer would be appreciated.
regards
p.s: In attachment , you can see that background is white already , but those parallel lines have to removed also. Thanks alot
Message 1 of 8
(4,529 Views)
Hi J.Dred,
these are the grids. You can change the color with a property node or with right click on the control in the properties. It´s an option from the axis.
Hope it helps.
Mike
Message 2 of 8
(4,524 Views)
Those "parallel lines" are the grid lines. You can just change the grid line colors to transparent.
Note that you can also draw graphs using the picture functions.
Message 3 of 8
(4,517 Views)
since I am using the german version, I definetely can`t find those grids, is it possible that make a small vi , background in white and sketch in black?
thank you very much
Message 4 of 8
(4,509 Views)
Which numerical version of LabVIEW are you using?
Message 5 of 8
(4,504 Views)
8,20
Message 6 of 8
(4,501 Views)
I have set the gitter colors to Transparent as given in attachment but the graph still has those parallel lines.
Message 7 of 8
(4,493 Views)
oh I managed to do it, thanks guys. ( I have changed to transparent in both axis 🙂
Message 8 of 8
(4,491 Views)
