backround bitmap BEHIND indicators.
Ok i give up, how do i force by backround bitmap behind my indicators.
Every time i place in the picture it covers the indicators.
(3,025 Views)
Are you editing the VI or are you programmatically changing it.  If you are editing it, place the picture on the VI and then select it and from the toolbar select reorder then move to back (Ctrl+Shift+J).  I am not sure how to change the order of programmatically inserted images.
Hope that this helps,
Bob Young
(3,020 Views)
Ok so i moved my picture to the back, thank you so much!
FOLLOW UP QUESTION:
How
(2,998 Views)
FOLLOW UP QUESTION:
How do I draw a LINE. just a simple line to point from my indicator to a location on my picture, just how do i freehand a line on the front panel.
Message Edited by Vr6Fidelity on 05-26-2006 09:45 AM
(2,999 Views)
You might wish to actually search the palettes first - the decorations palette has lines.
___________________
Try to take over the world!
(2,992 Views)
Got it, i feel so stupid, I forgot the pallates were different, AND it wont let you get to the pallate if you right click on the picture it wont bring up the pallates
(2,989 Views)
