backward compatibility problem V6.1 -> V7
It seems that V7 does not properly recognize V6.1 cluster references. Has anyone else seen this?
regards,
Ben
(2,583 Views)
Could you post an example?
I switch back and forth between LV 6.1 and 7 regularly and I have not experienced any issues.
I have even used LV7 to invoke a LV 6 VI and all of the clusters worked fine.
I do beleive there was a change to the Waveform data type and of course the new time format.
Trying to help,
Ben
Ben Rayner
Certified LabVIEW Developer
www.DSAutomation.com
Why do I feel like I am talking to myself?
(2,583 Views)
V6.1 example attached. In V6.1 main1, the connection between the cluster reference and the sub VI is OK, but if you import it into V7, this connection is broken. (I hope you get the same error as I do...)
regards,
Ben
(2,583 Views)
