band pass filter
Hi.
i am trying to implement a bandpass filter  blocking frequencies below 0.1Hz and above 5Hz with sampling rate of 50e-3. I have implemented it using a butterworkh as shown in attached but nothing is coming out, my graph and array are empty. Have I the filter configured correctly or is there another stage? Should I use a different filter block?
Many thanks,
Jim.
(3,290 Views)
Accepted by topic author jim346
You didn't posted your text file but from your diagram I would suspect a mismatch between your sampling frequency (50 mHz -> period of 20 sec ) and your loop timing (wait for .. set to 5 msec). Try to increase your sampling frequency or your loop delay.
Ben
(3,278 Views)
Thanks ben.
I was dividing into 1. Silly me,
Thanks.
(3,269 Views)
