bar chart
Hi...
I have a graph that plots after reading from a text file.I have to draw both line and bar chart.
Am using xy graph,and line chart is ok.Its plotting rainfall in accumulative manner.
The bar plot ,i tried by changing the plot type to bar plot.But its is some what diffe
each day may have many readinhs,i need to draw a bar indicatring that days total rainfall,and another bar to indicate the next days rainfall like that.
How do i accomplish this?
(4,380 Views)
Can u please post ur vi or screenshot, I m not clearly understood your question.
Balaji PK (CLA)
Ever tried. Ever failed. No matter. Try again. Fail again. Fail better
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved.
(4,376 Views)
Pls,check this attachment
(4,371 Views)
If you had specified "bar plot" as the plot type then it should look like a bar plot, unless you're not feeding the data correctly. Can you upload your VI and a sample set of data? Remember that if you have many readings for a day, then you need to sum the values up before you feed a sum to the plot. It's not going to give you a sum automatically.
(4,328 Views)
i have same problem. i have two choices to plot the graph, line or bar chart(radio button selection).if i select line, the graph is ok, but after i select bar, the graph is not ok...can u help me?
(4,125 Views)
Isn't the attached image what you want?
You have to select the type of bar plot, and select the interpolation style
Message Edited by Vsh on 11-25-2009 12:13 AM
(4,113 Views)
