barcode scanner for LabView
hey hello everyone
i am having problem with my labview programming. can some1 help me please
this is my coding like i detect my code using webcam ( vision acquisition) and
the main problem is that i need to detect TP022216 but am getting only TP02221
Message 11 of 13
(2,261 Views)
Hi Zahkay,
Have you tried reading other barcodes?
Make sure you have the right and consistent lighting, after this you can look into enhancing the image by applying grayscale filters or morphology as pre-processing steps for the 1D barcode reading. If you are new to image processing applications I would suggest reviewing the following tutorials:
Image acquisition system setup
http://www.ni.com/white-paper/4229/en/
Grayscale filters
http://zone.ni.com/devzone/cda/ph/p/id/110
Morphology Operations
http://zone.ni.com/reference/en-XX/help/372916P-01/nivisionconcepts/primary_morphology_operations/
There is also an example within LabVIEW that you can use as reference for your application when you install the Vision Development module toolkit.
http://www.ni.com/example/30533/en/
Luis S
Application Engineer
Message 12 of 13
(2,229 Views)
I would like to return to the topic of the initial question about the reader of the barcode reader. You have exchanged several models but all of them are rather branded. I would like to spend a bit less and I wonder if you could deal with a bar code reader of an unknown company. I'm thinking about barcode scanner HDWR but I'm afraid it will not work. It is not Chinese. I'm lokking for a ebay. Have you used some of the cheaper readers of an unknown brand?
Message 13 of 13
(1,474 Views)
