basic idea for Simon game
can anyone provide me the basic idea for how to develop the Simon game?
Thanks alot
Message 1 of 11
(6,075 Views)
Thanks alot
Learn how to program in LabVIEW.
Message 2 of 11
(6,044 Views)
Hi keat,
before you even start to learn LabVIEW you should understand the algorithms behind this "Simon Game"…
General comments (in case you don't get that after our two answers):
- this is a LabVIEW forum and we will be happy to help you with your LabVIEW problems
- when you have problems with your VI you should attach the VI (or a snippet)
- ask specific questions…
Message 3 of 11
(6,032 Views)
Hi all,just want to know which framework is better to develop the Simon game
a) state machine (event driven)
b) JKI state machine
c) QMH
Message 4 of 11
(6,007 Views)
Hi keat,
no need to start a new thread…
All these options can be used.
Using an event structure to handle user interactions is a great idea…
Message 5 of 11
(6,005 Views)
hi all,
any idea on transform VI below into a state machine event driven?
LabVIEW 2017
Message 6 of 11
(5,979 Views)
Hi keat,
  • Don't use (flat) sequence structures.
  • Use a case structure inside a loop.
  • Use an event structure.
What else do you need?
Comments on your VIs:
- Using non-latin chars in filenames is really annoying on "standard" English Windows… (Yes, it sucks.)
- You forgot to attach typedefinitions as well.
- To keep things in place yo should put all those VIs and CTLs in a LabVIEW project. Next time just ZIP the project folder (with all stuff inside)…
Message 7 of 11
(5,972 Views)
@ GeraldW
I still need to add username login and save the score and ranking of the user and also display the timer
Message 8 of 11
(5,967 Views)
attached is my current main VI
Message 9 of 11
(5,966 Views)
Hi keat,
I cannot read all those labels in your VI.
But from what I see I guess you already implemented some kind of "user managment".
The "timer" should be displayed in the timeout case of your (inner) event structure.
Is there a reason you need to use so many local variables? And stacked sequences?
Btw. I'm not "Gerald" - and you used to be "keat", but now you are "wayne"…
Message 10 of 11
(5,961 Views)
