basic level trigger
anyone pls help
i am using labview 7.1
with the vi 'basic level trigger', i need to determine the location of signal with the threshold level. for what i know, the vi can only detect once within one sampled block of data. if within one sampled block of data, it consists of many curves?with the same threshold level value, i need to determine many location(time/index), how m i going to do?
thanks for enlightening me
(5,001 Views)
If you look inside the VI, you will see that the Call Library Function Node that is being used actually returns an array of trigger locations. Index 0 is extracted but you can remove the array index function and have all of the detected trigger locations. Be sure to save the VI with a new name and in a new location.
(4,990 Views)
hi
thanks for the help.
sorry to disturb again. i have used the method.but it doesnt work. it still gives the same result which means only one location detected. in fact it has 2 values for each rising n falling edge.
i have gone into the basic level trigger to c the index array.it indexes 0. within one sampled block of data, it may consist of of many curve(for sure many rising and falling edge). preseting y value for let say 0.04 i need to determine many locations(time/index), is any other method to detect?previously i used 'basic level trigger'
thanks for the advice.
regards
(4,973 Views)
Sorry. One thing that I forgot to mention is the "max number of trigger pts" input to the Call Library Function Node. This is a hidden front panel control. Right click on the terminal on the block diagram and select 'Show Control'. Change the value to some high number and try it again. I don't have the VI I modified on the computer here but I remember trying a value of -1 to see whether that setting would return all trigger locations but I can't remember if that worked or not. It's an easy thing for you to try though.
(4,969 Views)
sorry
i have tried it but it doenst work either.
u told me to put the value of -1. i dun really understand.
if i use threshold 1d array, the output will b the same as in basic level trigger?i have tried.it is not my luck. it doesnt work either. i am at my wits end.
sorry for disturbing once again...
thanks.regards
(4,965 Views)
Here's an example that uses the modified basic trigger level detection.
(4,957 Views)
thanks
it works eventually!!!billion of thanks on your willingness to help
regards
(4,941 Views)
