basic transpose (not a complex conjugate transpose) of a complex 2-D array
Hi, folks
Just ran an old analysis that I had written in v6.1 where a 2-D complex array is simply transposed (not complex conjugate) for further analysis. Now, under 7.1, the code gives crap results. I've noticed that now LabView automatically performs a complex conjugate transpose on the array. Obviously, not what I want.
So, I changed the type to a real transpose, and which ends up truncating all the imaginary terms. No dice again.
Has anybody out there come up with a solution?
Would appreciate any help and/or empathy.
Frustrated,
Hunter
(3,226 Views)
Follow the 2D transpose with a complex conjugate function.
LabVIEW, C'est LabVIEW
(3,219 Views)
Thank you, Jean Pierre
My anger (at this hidden functionality change) was obviously getting the better of me, blinding the simplicity of the solution.
(3,204 Views)
Your anger is well founded. When these high level languages change routine functionality between versions, it can have disastrous results. And because it's an interchangeable piece, it could be buried deep within your code and you are on an Easter egg hunt to find why your code is broken.
Version changes with complex code scare me.
Sheldon
Technical geek, engineer, research scientist, biodegradable...
(3,193 Views)
You could file this as a bug. When a VI is converted from an older version, a complex conjugate node should be inserted automatically to restore previous behavior.
(3,187 Views)
