basic voltage output FPGA
I was wondering if some one could assist me, I'm trying to output an analog signal form a NI9264 module, my current code is attatched below. I'm sure I'm just doing something very silly but when I run the VI and turn the dial nothing happens, any help would be much appreciated.
(2,852 Views)
two suggestions.
first verify that your fpga vi runs by itself.  run the vi and adjust the control and observe the output.  if this works, move to step 2
two.  move the open fpga reference outside the loop so you only do it once.  i suspect that subsequent call to the open are returning an invalid reference.  if you wire and show error terminals, it may help
Stu
(2,834 Views)
