batch file at the end of installation fails to start executables
Hi all,
My app requires 2 external drivers to run. In the installer I did add installers for drivers to source files and simple batch file running one after another. Then in advance tab I did set to run batch file when installation is done. Unfortunately it doesn't work. When I run the batch file installed thru Labview installer in Program Files folder (C:\Program Files (x86)\mySW\) it installs everything, but when the LabVIEW installer runs it at the end of installation it fails because of the wrong path:
    C:\Users\xxx\Documents\mySW\builds\MySW\Volume>ti_msp430driver_setup_1.0.1.1.exe
    'ti_msp430driver_setup_1.0.1.1.exe' is not recognized as an internal or external command,
    operable program or batch file.
in advanced tab the path is set to: ProgramFilesFolder\mySW\external installers.bat so in theory it should start batch file from program files folder and pick installers from program files as source files?
(1,433 Views)
Did I understand right that your case is similar to this topic?
__________________________________________
The best way to thank, is to give KUDOS
(1,362 Views)
