batch file output
I am programming some devices with batch files using the System Exec.vi. I am not getting anything at return code, standard error or standard output. Should I be getting something at these terminals, especially if my batch file fails?
PaulG.
Retired
(3,245 Views)
Hi Paul,
do you get an output if you call the batch file from the command line? What do you mean with "if the batch file fails"? Where should the error come from?
Mike
(3,221 Views)
I'm programming PIC's, and if the PIC programmer isn't plugged in the DOS command line returns "PIC programmer not found". I need to automate this process if possible.
PaulG.
Retired
(3,207 Views)
Hi Paul,
i think the order of "cmd /c" is important. Did you see the example in "examples\comm"?
Mike
(3,195 Views)
