battery charging
Hi ! I am a students from France and I would like to know how to obtain the flow rate of a battery. I need to obtain a curve of the load and the discharge of the battery with this software. How can I do that ?
Message 1 of 9
(4,867 Views)
How are you connecting to the battery?
Message 2 of 9
(4,848 Views)
with wire to the battery terminal
Message 3 of 9
(4,840 Views)
That's just a silly statement. What sort of hardware do you have in order to measure voltage and current? That's the sort of connection you need to explain about.
Message 4 of 9
(4,829 Views)
Adding to what Dennis said, how do you expect us to help you if you hide all of the details? Do you WANT help?
Message 5 of 9
(4,818 Views)
Yeah I would like to get help, sorry if my statement isn't good enough. Indeed it's gonna be my first time on lab view thursay and I need to get some informations. That's why I come here. Which hardware do I need to measure the flow rate and transfer it on labview to get diagramm
Message 6 of 9
(4,791 Views)
Something like a source-measure instrument from Keithley is often used but anything that can source a voltage and measure current will work. Check to see what your lab has.
Message 7 of 9
(4,780 Views)
Ok in our lab I'm pretty sure that we have source measure now I would like to know if possible what should I do on the software to get the informations and transform them into curve
Message 8 of 9
(4,771 Views)
First, study the instrument manual and experiment with setting it up and taking a reading manual. Then, on LabVIEW, try Help,> Find Instrument Drivers. Search for your make and model. Look at the main page -http://www.ni.com/downloads/instrument-drivers/ for information on what a driver is and how to use one. Before that, take one or more of the free LabVIEW tutorials.
Message 9 of 9
(4,760 Views)
