bayer to RGB conversion on FPGA
I want to convert bayers data to RGB on FPGA. I am using IMAQ FPGA Bayer to RGB.vi to convert my data. I am running the VI in simulation mode, I have attached the snap shot of my block diagram.
My input data is in the below pattern.
     1st Line  :RGRGRG...
     2n Line   :GBGBGB...
     3rd Line :RGRGRG...
     4th Line :GBGBGB...
As I cannot use 2-D array on FPGA so above shown pattern is converted into 1-D array  by connecting 1st Line, 2nd line & so on.
My problem is every time the VI is giving 0 as output & May be I am giving any wrong parameter to the VI so please give any suggestion  to convert the bayer data to RGB.
Message 1 of 1
(3,124 Views)
