bc637
I have a Symmetricom bc637 card and the software development kit (SDK) for the card.  I have been able to talk to the card using LabVIEW library function calls using the dlls provided with the SDK but now I need to set up for interrupts.  The example code they provide sets up a thread that polls to see if an interrupt has been generated and then prints "Got Interrupt".  I could easily copy their example written in C++ and put in my own requirements but I can't see how to do this using LabVIEW.  It looks like I would have to write a dll using C++ to start a thread.  Is there some other way to do this?
(3,135 Views)
You can try putting your code in a Dynamic Link Library (dll) and then calling it using the Call Library Function node. Hope this helps!
Ipshita C.
(3,119 Views)
