beckhoff
I want to connect a Beckhoff system with LabVIEW. I know you have to place an ActiveX component in your VI. But every time when I want to insert the AdsOcx Control as an activeX component, I get the following error:
klasse is niet geregistreerd
Class not registered
(see attachment)
Has anyone ever had the same problem?
Thank for helping
Greets
(3,838 Views)
Hello Pieter,
Can you give some more information about the steps you are currently taking?
Is your ActiveX object registered?
Can you givesome more information about which type of Beckhoff system you're using?
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
(3,810 Views)
These are the steps that I do
In LabVIEW I insert an ActiveX container. And in this contaiener I insert an ActiveX object named AdsOcx Control.
I'm using a BK9050 ethernet coupler. I think that the ActiveX object isn't registered but I don't know how to do it.
Thanks for helping
Kind regards
Pieter
(3,791 Views)
Hello Pieter,
Have you already googled it?
Just searching with the search terms "register activex component" gives back the following result:
http://support.microsoft.com/kb/146219
Kind Regards,
(3,787 Views)
