beep.vi does not sound
@michaelclewis92 wrote:
How do i change it to the actual VI?
What is "it"?
At any point during programming you can save the VI. This will create a file that you can attach to the post. The attch button is below the post composition window.
Message 11 of 18
(1,433 Views)
Oh, sorry do you mean like this?
Message 12 of 18
(1,420 Views)
You haven't attempted to put the Beep VI into a case structure.
It is also a good idea to convert the blue DDT wire to something meaningful like a scalar value right away.
Message 13 of 18
(1,416 Views)
You have wired a dynamic boolean to the input named "use system alert?". This is NOT a "on/off" selection, but determines if the other two inputs should be ignored or not. There typically will be a sound if it is TRUE or if it is FALSE.
Sorry, I don't have DAQ installed. What is the loop rate of your VI?
Message 14 of 18
(1,407 Views)
How do I find out the loop rate?
Message 15 of 18
(1,380 Views)
As a first approximation, It probably depends directly on how you have configured the data acquisition. Sorry, I cannot see the configuration because I don't have DAQ installed here.
You can also simple measure it, of course. 😄 If you place the following code inside the loop, it will indicate the loop time:
Message 16 of 18
(1,359 Views)
Hello Altenbach!
I'm using an ADQ (PIC 16F1847) and i do use a loop to display my values.
So what id like to know is the actual refreshment rate of my graphs (or the interval between 2 loops)!
Your link seems to show exactely what i need...but i absolutely cant find that watch icon
Thank you a lot
Sorry replied to the wrong post and apparently cant remove it
Message 17 of 18
(1,330 Views)
Tick count (ms) in the timing palette.
Message 18 of 18
(1,324 Views)
