[begginer] Multiple string controls, one string indicator
Hello! I started learning labview this week, maybe this is a silly question
I have to indicate if a pressure I entered is normal, low or high using only one string indicator. Can't figure out how to do it...
(3,702 Views)
That sounds like a series of comparisons.  Look at the Select function.
(3,693 Views)
Several "ideas" are common in programming.  One is "repetition" -- do something multiple times.  Another is "choice" -- do only one thing, but "depending on something".
In LabVIEW, some of these "big ideas" are manifested by structures on the "Structures" Palette (well, where else?  Duh!).  Does anything in the top rows suggest an "idea" that will help you with your question?
Bob Schor
(3,684 Views)
@RavensFan  escreveu:
I was trying Select but I could only show 2 strings (high or low, high or normal, low or normal). I can't figure out what to do with the third...
(3,675 Views)
@Bob_Schor  escreveu:
Bob Schor
Don't know if I'll need structures (only know loop yet) here, because I'll enter a pressure value once and it must tell if it's high, low, normal
(3,664 Views)
You can put the result of one Select into a 2nd comparison where you get the 3rd.
It's like
If x< low then
   pass along "LOW"
Elseif  x> high
 pass along "HIGH"
Else
 pass along "NORMAL"
Endif
(3,649 Views)
