[beginner] Spreadsheet string to Array
I just want to display string data in a table.
I read a line of string data (tab separated) with "Read line from file.vi"
then i use spreadsheet string to array (format: %s ,separator: tab) but
the result is not an array of string but an array of DBL !
What's wrong ?
Thanks for help !
(3,562 Views)
On Tue, 16 May 2000 08:32:03 +0000, "y.leroux"
Wire an two dimensional array of the type you want to the input
'array type (2D dbl)'
(the string '2D dbl' indicates that the input defults to a 2D dbl
array if unconnected)
For you it would be an two dimensional string array.
Rolf
(3,562 Views)
