beginner at labview robotic module : robotic arm control
i am dealing with a project that aims to control a robotic arm (5-axes), but at first time i want to get familiar with these types of problems, so i want to control this 1-axe arm.
i design a simple arm and i upload it in that scene (as shown in the picture below
so my question is how can i command this arm ( using for eg kinematics, inverse kinematics ...)
(2,427 Views)
Hope it depends on the Controller type and the communication involved in that, and for Each function to perform there will be command which will be specific to the controller.
Waiting to hear from others on thisSmiley Wink
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(2,411 Views)
