bertan 225 power supply
The VI downloaded from labview driver website could detect the bertan power supply, but couldn't control the output voltage. I would like to source voltage and measure current. I've turned the control on the power supply to IEEE but still not working. Anyone has experience with this power supply? Please help. Thanks.
(2,393 Views)
Hi Cas_Sun,
I found another forum post dealing with what seems like the same issue with the Bertan 225 Series.
If you open up LabVIEW and go to your Example Finder application under Help >> Find Examples, you should be able to find a VI called Simple Serial.  Try using copying the code from this example and trying to connect to your device through this.  If we can make a connection through this example, we'll be on good footing to move forward with debugging.
Tyler O
Tyler O.
(2,351 Views)
Cool, I will give it a try and let you know if it works. Thanks so much!
(2,342 Views)
