best way to control a large num of controls and indicators
  1. If you are new maybe you should start with some learning the basics (state machines, shift registers, Event structures, etc.), and not trying to make a full functional feature-full application first ( https://forums.ni.com/t5/Community-Documents/Unofficial-Forum-Rules-and-Guidelines/ta-p/3536495 under "Looking for free training")
  2. Cluster with Event: https://forums.ni.com/t5/LabVIEW/How-do-I-determine-which-control-in-a-cluster-fired-the-lt-All/m-p/... Similar: https://forums.ni.com/t5/LabVIEW/get-cluster-element-when-changed/td-p/2907870
  3. Some more discussions about clusters and state machines: https://forums.ni.com/t5/LabVIEW/Clusters-in-state-machine/td-p/1330032
In this last link, It is explained just almost the same way as I adviced you in my previous link, you can use a typedef cluster in a shift register your your state machine: https://forums.ni.com/t5/LabVIEW/Clusters-in-state-machine/m-p/1330044/highlight/true#M541821
Edit2: an example of a simple single loop state machine with Events: https://forums.ni.com/t5/LabVIEW/Clusters-in-state-machine/m-p/1330060/highlight/true#M541822
Message 11 of 12
(1,161 Views)
Accepted by topic author afetsis
Well, you could look at my earlier post to this question.  This is a Cluster of 5 Arrays.  The first is an Array of 16 Booleans (representing the bits of a 16-bit DIO Register).  It has a Label of "Lasers", not visible, and a visible Caption of "1 2 3 4 5 6 7 8 9 F   O I P H" to label some of the individual bits (Laser 1-9, Fixation, Outer, Inner, and Head).  The point is, with a Cluster you can group and design (and Label) the individual Boolean Digits (a.k.a. "Bits") and keep them grouped and yet still individually accessible.
Bob Schor
Message 12 of 12
(1,149 Views)
