best way to empty the array?
In LabVIEW PDA module, what is the best way to empty the array?
The reason is that I have an array variable which is loaded with different data sets. It looks to me using the loop to reinitialize the array is not the best way.
(3,176 Views)
I am not aware of how arrays are used in LabVIEW PDA, but normally, you can use the property node of the array to empty the array. hope this helps!
(3,153 Views)
Right click on the array terminal and select Create>>Constsant. You'll recieve a constant with the current value of the array. Make sure the constant is empty and wire it into the array (or a local variable) wherever you want on the diagram. You can also use Initialize array VI.
___________________
Try to take over the world!
(3,142 Views)
