bin to hex
Hi : For example I have Binary Number 10110000 that I what to convert it to Dec Number
How can I do that in labview
thanks
(4,004 Views)
Hi Elyan,
have you tried: programming -> numeric -> conversion ?
TN
Currently using LV 8.5
logo
(3,995 Views)
Did you try out the numeric format converter functions in the Numeric/String pallette?
If you want to change the format in a COntrol/Indicator, just rt-click >> Radix will do the job for you. Smiley Happy
But see that your question header & your problem description are not the same. Smiley Wink
- Partha ( CLD until Oct 2027 🙂 )
(3,992 Views)
Accepted by topic author elyan
As the information you give is incomplete, we're doing a bit of guessing here.
If the 'binary' is in an ASCII text string (so that you could display it in a string indicator in normal mode) you can convert it to an integer (perhaps a U16) using "Scan Value" with "%b" as the format string. Then just set the display format of the integer to get the visible formatting you need.
Rod.
(3,986 Views)
(3,984 Views)
