binary data modulation suggest
i am having 32 bit binary data(111101010101....), modulate and demodulate the data by using simple ask transreceiver.vi
after demodulation i got only 26 bit binary data
first bit and last 5 bit in the 32 bit data are gone
only 26 bit is available
pls help suggest whether the problem in the simple ask transreceiver or something else
(3,066 Views)
Have you checked the x-scales of your graphs?  There seems to be a lot of waveform data that appears at x-values to the right of what is shown in the graph that I found when I picked autoscale X axis.
(3,059 Views)
