binary file open .. problem with formatting
dear all,
probably it is too much time I am not using any more Labview, but I have a problem in opening the attached data file.
 it is supposed to be a matrix of 1000x316, with integer values up to 16 bit (65k levels).
In matlab i open it with fopen command, and assigning the format as "uint16"..
now I want to create a quick viewer in labview, but I can not go beyond the classic binary string...
may you help me with this stupid problem?
regards,
Edo
(3,124 Views)
Accepted by topic author Edo777
Is this what you need?  It results in a 1000x316 array of U16s.
Message Edited by jcarmody on 01-08-2009 12:07 PM
Message Edited by jcarmody on 01-08-2009 12:08 PM
Jim
(3,116 Views)
ehi... so easy ... that was perfectly what i needed, i was begging around with formats...
thanks a lot,
Edo
(3,107 Views)
