binary string to hex limited to 32 bits
hello,
is there a way to convert a binary string to hex for more than 32 bits.  i attached a vi that does the conversion, but i can't figure out how to do it if my input binary string contains more than 32 bits.  thank you
(4,184 Views)
How may digits do you need? If 64 is enough, you could set the default to U64 and keep the rest as is. (You should place a small wait in your while loop though).
You should also set the lenght to the right size when you format to hex (8 for U32, 16 for U64, 2 for U8), else you'll potentailly loose leading zeroes.
For unlimited lenght, you need to e.g. use a loop. Attached is one simple possibility. (Be careful if the input string lenght is not a multiple of 8 or if it contains garbage characters).
(4,179 Views)
Thanks for the reply.  There could be a possibility anywhere from 0 to 240.
(4,173 Views)
