binary to decimal
Hi All
i want to convert binary array to decimal number. give me some idea
(16,782 Views)
Try looking on the function pallet where you might expect it to be?
(16,777 Views)
Functions-->Progamming-->Boolean-->Boolean Array to Number
=== Engineer Ambiguously ===
(16,755 Views)
If the binary array that you talked about is in boolean format (an array of T and F), you can use Boolean array to number.  If not, you can write a loop to convert the 1, 0 to boolean and use the boolean array to number function.
Yik
Kudos and Accepted as Solution are welcome!
(16,752 Views)
If the binary array is an array of 0,1s feed it into a Not Equal To 0? and then the boolean array to number function
Omar
(16,743 Views)
Thanks All
(16,702 Views)
