bit to number conversion
Can anyone help me URGENTLY on converting a byte into a integer in order to graph it? Tnx
(3,047 Views)
If your "byte" is a U8 (or an I8), use the numeric conversion (on the Numerics pallet) to convert it to I32 or whatever else you want.  If your "byte" is a character (or a character string), use the string-to-byte-array conversion (on the String pallet) to create a U8 array, then apply the first-mentioned solution.
Bob Schor
(3,045 Views)
You have to be a bit more clear what your "byte" is? (single character binary string, etc.).
Most likely you have a string, so just typecast it to a U8 or I8, depending on your requirements.
Again graphing a single byte does not seem very interesting. Do you use a chart? Do you have many "bytes"?
(3,044 Views)
