bits multiplied by carrier
Hello all,
if i have for example an array with 0's and 1's
and i want to multiply each by a sine wave
and after putting it on a chart
i want to retrieve the bits again
how can i do that..i think i have done the first part where i multiply each number by the sinewave
but i don't have any idea how to retrieve them
Thanks all,
(2,517 Views)
Before attaching a sample VI, please populate reasonable default data into all controls and make the values the default. (currently, the array is empty and the numeric is zero).
Thanks all,
Where do you want to retrieve the bits from? Form the chart data? The chart only has limited history!
I don't think you even did the first part yet.
I think once you specify in more detail what you actually want to do, the solution would be easy. 😄 At the moment, things are not clear at all.
(2,497 Views)
